Ok, heres what I got so far, I'm gonna have a 2 loop system in my system, by 2 loop I mean one loop dedicated to cpu and misc and 1 dedicated to GPU/GPU's (depending on weither I can afford 2 cards CF or SLi haven't decided witch to go with) what I need to know whats the point of resoviours and where should I put them after the loop (after gpu's and etc) or right after the radiator(before GPU's and etc) and second of all do you think I could use a TEC safely in this type of a setup on the gpu's (and perhaps the CPU) mind you the radiators will be a dual 80MM with 4 80-CFM tornados on each radiator (2 radators, 1 for each loop) (don't worry about how loud it will be, I'm deaf) reason fo using dual 80mm radators with 4 fans on each
is the fact that I can fit the 80mms inside my case, barely, but still and the air flow will be set up in a method that is benifiaray ( in front where 1 rad will be, the fans will suck into case, while in the back where another rad will be it will blow out of case as well as other misc fans here and there for Ram and etc) so once again it would be great if someone could help me with my water cooling endevors, btw I know each loop will cost me around $400 for a total of around $800, but most of the parts will be re-usable so I see this as an investment, also I do not wanna go vapor.... Yet so don't suggest it
Thanks alot in advance
Chilly (heh this brings new meaning to my nickname
