Planning on Getting a Nikon D1 or something
DaCoOlNeSs
well I hope to buy one, I am tired of having to borrow SLRs, it is very annoying. Any advice? Or a better suggestion perhaps?
well I know a guy who can lend me some Nikon glass till I buy my own, and I already have a CF card / flash.
How much money do you have to spend? You could probably get a D70 or D100 and then some glass for the same price as a D1, and you won't be missing much....
I'd probably go for one of the newer, more advanced Nikons. The D70 is great, I have not used the D100 however. Both are $1000 - $1300 depending on what you buy, and then you still have money for a good quality lens.
I think the D1 series are still around $1700 for one?
actually, nevermind. I just found that i can buy a Nikon D100 for $1200 and then use the $200 rebate off of Nikons site, and then go buy an MBD100 so I can have vertical shutter release. thanks for the help though!
