Planning on doing a good upgrade soon
cinohpa
I currently have:
A8N-SLI Deluxe mobo
AMD Athlon(tm) 64 processor 3500+ 2.21 GHz
1 gig of corsair xms RAM (two 512 sticks)
I plan on adding/replacing:
My old CPU with http://www.newegg.com/product/product.asp?item=N82E16819103759
and
adding another gig in two 512 sticks of the same ram: http://www.newegg.com/product/product.asp?item=N82E16820145420
I'm wondering if maybe I should think about video cards now. I have an NVIDA 6800 256mb. How long will it be before a DX10 card will be a necessity? I'm not huge on games, but I generally get the big ones. I would be happy playing my CS, WC3, Far Cry, Doom, etc for a while still so I don't really see a huge reason to get a new video card.
Also, In about a year I plan on building a much higher end rig. I don't want to put too much money into this computer right now but I want it to be highly functional even after I build my new rig.
Thanks!
-Cinohpa
Another concern is that the processor I want might get discontinued. I've talked to a few people about it and they've said I should order my CPU soon for that reason.
You can always find CPU's used or new. Do this upgrade and if you're happy with everything don't worry about it. It will be clear to you when you need to upgrade. Doubling the ram and increasing the processor power will speed things up as it is.
hold off on the new gpu until you build your higher end rig.
