Planning on buying...please comment
Mokster
These prices are Canadian ... so bear with me :/ I already have a monitor and will be getting an ATI x1900xt at a good price..any comments are welcomed!
ASUS A8R32-MVP Deluxe A8R32-MVP-DLX $222.99
Antec P160W $119.95
Hiper Type R 580W ATX12V V2 24/20 Pin Blue Power Supply 120MM Blue LED PCI-E W/ Detachable Cable HPU-4B580 $149.98
Corsair XMS Twinx PC3200 2GB 2X1GB DDR400 CL2.5-3-3-6 184PIN DIMM Dual Channel Memory Kit TWINX2048-3200C2 $258.06
AMD Athlon 64 X2 3800+ 2.0GHz Dual Core Socket 939 512K L2 Cache ( Retail Box ) ADA3800BVBOX $339.98
Seagate Barracuda 7200.9 SATA NCQ 3.0Gb/s 300GB 16MB Cache (OEM) ST3300622AS $137.70
Samsung SH-W162 16X DVD+-RW 5X Dual Layer DVD Writer Black /W SW OEM SH-W162C $39.99
Cooler Master Neon Blue LED 120MM Case Fan 3PIN 22DBA 1220RPM 42.734CFM 3PINS TLF-S12-EB $7.88
I have never heard of the brand known as "Hiper".
Brand is extremely important when buying a PSU.
Is it well reviewed?
I recommend the Enermax 620 Watt Liberty PSU.
It is modular as well and is very spiffy.
The rest looks good.
i have the case and its really nice
i also have the fan and its nice also ;)
I changed to the Antec NeoHE 550W...
For the price you have listed on that PSU I'd suggest getting a PCP&C 510 Deluxe or something along those lines. Basically one of the best supplies you can get.
Also are the 7200.9s the new perpendicular drives or has anything else significant changed on them. I've been using a bunch of 250GB 7200.8s and they're going for like 85US. Might look for a performance graph and see just how much they improved because 138CA is kind of steep.
And of course it can't hurt to recommend a second 1900. Because 4 heads are better than 2. lol
actually i was looking at the PCP&C, still too expensive, the neohe 550 i switched to is only CAD$130...
7200.9 is the Seagate Barracuda 7200.9 SATA NCQ 3.0Gb/s 300GB 16MB Cache link
Antec P160W $119.95
where r u getting these prices from???
Mokster said:
NCIX.com canadian prices...
do u live in the toronto area......should try going 2 the spadina & collage area......lots of stores down there & better prices.....
Yes, Hiper is a good brand, and their Type-R's are considered one of the better modular PSUs out there.
yes, i'm Toronto area, but do they have online website or I have to go in to check prices?
