planning on a small upgrade
vict0r
i want to do a small upgrade
only game i play is CS:S ...
Other stuff are just daily internet some office apps etc etc
so this is about my budget atm.
Motherboard GIGABYTE GA-EP45-DS3L
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128345
CPU E5200
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116072&Tpk=e5200
Cooler XIGMATEK HDT-S1283 120mm Rifle CPU Cooler
http://www.newegg.com/Product/Product.aspx?Item=N82E16835233003
Memory CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145590
Vidcard geforce 9600gt (i already have)
hdd Western Digital Caviar SE16 WD6400AAKS 640GB 7200 RPM 16MB Cache
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136218
PSU PC Power & Cooling S61EPS 610W
http://www.newegg.com/Product/Product.aspx?Item=N82E16817703005
Planning on atleast a 3Ghz OC ..
i am also wondering if the gigabyte mobo will recognize the e5200 out of the box?
the psu selected is 610w and i'd like to leave it like that(or at least in that direction).. i know i could get a 450watt corsair mobo for a lot cheaper and be sufficient.. but i rather get that pc&c to expand a future upgrade..
anyways..let me know what you think
thanks.
v.
I think that tells you that it all sounds good. The Gigabyte MB should recognize the chip at least enough to get a BIOS update done if need be - should be no problems for you at all.
more memory is always better.... until you're at like 8gb +
and then you're just wasting money
(not directed at photoshoppers/etc)
thank you.
i was thinking about going 2x2 gigs instead of 2x1
Yea, I made that mistake. Go for the 2 X 2.
The smaller power supply would be fine unless you think you may want to SLI or Crossfire in the future. I went with a Coolermaster 450 on my system.
Don
If you care about noise then the PP&C supply shouldn't be on your list - it's 80mm fan can be really noisy. You could look at a nice Seasonic for quality power and silence.
i picked the pc p&c 610 because one never knows what i would like to do in the future?
maybe i decide on going with a quad next and a bigger power hungry videocard..
so i rather play it save this time...
