mmm-sandwich
- May 2, 2007
recently i've been trolling [H] and it made me want to OC again. my last overclock was an AMD duron 650mhz to 800mhz, pretty sweet huh?
for this OC i'm aiming for 3.2-3.4ghz and any input/advice/criticism/whatever will be appreciated.
i've been working on this build for several days now, i'm trying very hard to spend less than $450 on everything. i'm going to use the video card from my current system (x1650 512mb). anyway here it is:
http://www.newegg.com/product/product.asp?item=N82E16811147073 - case, it comes with 1x 120mm fan so i thought i would get another for $3 and make a front to back wind tunnel.
http://www.newegg.com/product/product.asp?item=N82E16813128042 mobo, seems like the best OC'ing board, bang for buckwise, and i'm on a very strict budget.
http://www.newegg.com/product/product.asp?item=N82E16819115016 e6420, it's only a couple dollars more than the e6400 and i've read mostly good things about them.
http://www.newegg.com/product/product.asp?item=N82E16820340029 APIDA 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) - this is the first thing i am unsure of, after less than an hour of research i found some specs for this memory that said the timing was 4-4-4-xx, but i am doubtful, the reason i chose this was because it was the cheapest 2gb of ddr2 800 on newegg.
now to to HSFs, i've spent many hours trolling the [H], newegg, and many other places and i have a few questions.
http://www.newegg.com/product/product.asp?item=N82E16835207001 would this be enough to reach 3.2ghz with the cpu i chose? it seems to be a cheaper version of the Arctic Freezer 7 Pro. what other HSF would you recommend for my build for under $25? also what thermal grease do you use to get the best connection between HSF and CPU?
edit: also looking for PS recommendations, how many watts am i going to need and can you recommend a good value PSU to meet my needs?
