- Jan 11, 2009
Here's the challenge: Get the most performance from the smallest package, on a budget. I already have my gaming machine, so this will be somewhat of a project rig.
Parts so far:
M300 case:
http://www.mini-box.com/M300-Enclosure-w-Bootable-CF-Reader_2
AMD PII 905e
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103682
Zotac GF8200 motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813500021
Hard Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148446
Memory
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231166
PicoPSU
http://www.mini-box.com/picoPSU-150-XT-102-power-kit
That's basically it right now. BUT, what I really want to utilize in this build, is the extra PCI slot on the M300 case. and my X-Fi Titanium. The problem is the heatsink height of the 905e, which I'm not sure of, so I may need to invest in an extremely short heatsink as well. Also, I'm having a lot of trouble finding the appropriate flex riser for the PCIeX1 slot so that I can mount the X-Fi Titanium sideways.
Does anyone have any suggestions for a heatsink that would fit in the M300, potentially underneath the X-Fi Titanium sound card, and also a good cheap flex cable? The only one I've found is about $50
Parts so far:
M300 case:
AMD PII 905e
Hard Drive
Memory
PicoPSU
