Planning a node 804 build need fan advice
Draconian
Planning on using this rad:
http://www.frozencpu.com/products/1...40mm_Radiator_-_80mm_Thick.html?tl=c95s667b42
having trouble with deciding a good fan to do push/pull in a 140mm size or would I be better running the 2x120mm variant? may also consider adding a single 120mm or 140mm as well.
build is still in planning stages but so far thinking of doing a 2x290x or a 295x (or whatever it ends up being called) with x99 or z97 build undecided cpu wise
Edit: Case: http://www.fractal-design.com/home/product/cases/node-series/node-804
