Planning A New System, Need Advice On Components
lkramer
I will be using the computer for development, gaming and to host a Linux VM.
My budget for the motherboard and processor is CAD$500. But my total budget for the build is CAD$5500.
I live in Toronto, Canada but can travel easily travel to the Micro Center in Cleveland or Detroit.
I need a motherboard and processor.
The components that I currently have or will be getting are 2 R9 290 in Crossfire, 16GB (4GB x 4) 30nm Samsung RAM, 256GB Samsung 840 PRO, Case Labs SM8 case in reverse ATX, 2TB WD Black drive and a Seasonic Platinum 860W power supply. The liquid cooling parts, I will use an Alphacool UT60 360mm radiator in the front, an Alphacool UT60 480mm radiator in the bottom, a D5 pump with a Koolance top/reservoir, and EK blocks for both the CPU and GPU.
6) Will you be overclocking?
Maybe, but it is a not a priority for me.
My current resolution is 1920x1080 but I will upgrading to a 1440p monitor (or maybe even an Ultra HD monitor) in the near future.
At the end of this month (May 2014).
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
It will need Crossfire support. It needs at least one USB 3 port on the back panel. I would like one front panel header and eSATA but it is a requirement. No, it is does not need onboard video. It needs to support UEFI.
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
Yes, I have a legit and reusable OS key. It is Windows 8.1 Pro 64-bit.
I can get an Core i7 4820K and a MSI X79A-GD45 Plus, or a Core i7 4770K with a Gigabyte Z87X-UD3H for the around the same cost, US$432.
Or, maybe, I should go with the Core i7 4790 with the Gigabyte Z87X-UD3H as this processor has VT-d which could help with the virtualization. Does VT-d provide a performance boost to one VM with a moderate amount of disk I/O during compilation and low network I/O?
Also, the locked Haswell processors have transaction memory extensions enabled which maybe interesting to try as a developer.
I have narrowed it down to these three motherboard and processor combinations, but I need advice on which of these is the most suitable for me.
Dear Ikramer,
If you may, kindly review your preferable eventuality
1. Are you a one-size-fit-all grand builder ?
2. 4-wheel rammer ?
3. suitable precise tools for relevant tasks relatively original Unix philosophy?
4. Continuous improvement enthusiasts, p movers...
Due to your stated available total budget, above are possible.
For example only, not real suggestion
For 1, maybe dual-socket full blown everything, last some years
For 2, maybe single socket with almost all premium stuff thrown in, I guess this forum users expect at least two years.
For 3, maybe just game console for gaming, PC for development and VM. Some may even split VM to separate host, and a NAS for completion...
For 4, maybe any doable single unit for start and continuous upgrade of multiple options on multiple aspects as your move along
Just a thought...
Cheers
