- Mar 12, 2006
I'm planning a new build around the Rocketfish Tower. I have not finalized a hardware plan as I want to start setting up the case without installing/removing hardware.
I'm thinking something like this though:
Intel E7200 or E8400
Asus 750i SLI or DFI Blood Iron
9600GT SLI'd or 9800GTX (depends on which chipset I decide to use) (I'm going to start with one 9600GT either way and either stepup to the 9800GTX or add a 9600GT. I'm just really digging the benchmarks I've seen with the 9600GT SLI'd)
2x1GB Buffalo Firestix PC2-6400 (I already own these so I'll use them to start then swap to a 2x2GB kit later)
Corsair 620HX (already own and love it)
Seagate 320GB 7200.10 (already own and will grab a 150GB Raptor later down the road as a main hard drive and use this as a spare. Also will have room for up to 4 more hard drives later down the road as well. But I'll probably remove one hard drive cage and just stick with up to three.)
I'm thinking about doing a fillport and drainport, with a Danger Den fillport res; BIP III radiator on top, use my pump I already have and probably just try to get just the CPU in the loop to start.
I'd like everything to be G1/4" fittings and use either compression fittings or no clamps on the tubes for a cleaner look.
If anybody can give me comments on what kind of gear to get as the only other watercooling I've ever done was with a Swiftech 120mm kit.
I'd like to place the order sometime today (Tuesday) so I might get it by the weekend to start building.
