Planned build.
JenniferSifre
Choice #1.
Athlon 64 3700+ (San Diego)
Asus A8N-SLI Deluxe
Antec TruePowerII 550W PSU
Sapphire X850XT Pci-Express
1GB Corsair Value
SB Audigy2 ZS
80GB Maxtor 8mb Cache
Or should I go Athlon 64 4000+ San Diego and eVGA 6800GT to balance things out? Thanks.
I'm only going with one video card now until the next gen stuff comes out. I just want the main upgrade path taken care of, geez.
Well, I haven't seen a pictures of the next-gen stuff (so don't flame me), but most likely, you won't be able to SLi it. The other slot will most-likely be taken up with the fan.
I apologize for my previous post. I really can't afford the two 6800's right now. Stretching my budget pretty thick as it is. Basically, I just want the SLI mb and decent cpu in the event I do decide to go with dual next gen cards in the next 6 months. Basically, I'll sell the 6800GT and use the leftover cash towards the new cards (I've decided to go with the Athlon 4000+ SD as well).
And I'm hoping you can do SLI with the next gen stuff. :mad:
