Just starting to get into Liquid cooling and am trying to plan my first build. The build will be going in a Corsair 760T Full Tower Case.
I hope to order parts in the next day or so; and here's what has my eye:
Phobya CPU-Cooler UC-2 LT Intel 775,115X,1366,2011 - Silver Nickel Plexi Edition
http://www.performance-pcs.com/catalog/index.php?main_page=product_info&products_id=38259
DDC Photon 270 Reservoir/Pump Combo
http://www.performance-pcs.com/catalog/index.php?main_page=product_info&products_id=40972
Tygon E-3603 3/8" ID (1/2" OD) Clear Tubing
http://www.performance-pcs.com/catalog/index.php?main_page=product_info&products_id=37374
XSPC RX360 Triple-Fan Radiator V3 Black
http://www.performance-pcs.com/catalog/index.php?main_page=product_info&products_id=40066
Phobya ZuperZero UV Green 1000ml
http://www.performance-pcs.com/catalog/index.php?main_page=product_info&products_id=30637
XSPC G1/4 to 3/8 ID 1/2 OD Compression Fitting Chrome
http://www.performance-pcs.com/catalog/index.php?main_page=product_info&products_id=39022
XSPC G1/4″ 45° Rotary Fitting - Chrome Finish
http://www.performance-pcs.com/cata...oduct_info&cPath=59_346_951&products_id=38171
XSPC M20 Fillcap Blank Chrome
http://www.performance-pcs.com/catalog/index.php?main_page=product_info&products_id=39904
Alphacool G1/4 Thread 90° Rotary 3/8" ID x 1/2" OD Compression Fitting Chrome
http://www.frozencpu.com/products/1..._ID_x_12_OD_Compression_Fitting_-_Chrome.html
Alphacool G1/4 Thread 45° Rotary 3/8" ID x 1/2" OD Compression Fitting Chrome
http://www.frozencpu.com/products/2..._ID_x_12_OD_Compression_Fitting_-_Chrome.html
I haven't decided if I want to go with compression or quick connect fittings yet. Any thoughts?
