Planar PX2210MW (ANYONE??)
stangn99
Looking into picking up 2 new monitors for Graphic Design work.
My budget is $800 for BOTH. I would like 2 x 21"+ widescreen.
I saw the Planar PX2210MW on Tigerdirect for a little under $400 CDN... Anyone know what type of panel it is? Can't seem to find any info on it.
Viewing angles would have told that it's TN. Non-TNs are advertised with 178/178 (176/176 in some) viewing angle... and TNs extremely exaggerating 170/170 or under.
In widescreens available sizes are 20 and 22 inches.
Among 22" TN junks there are now "standard" resolution Eizo S2231 and higher res 1920x1200 Lenovo L220x both with new S-PVA panels, they just cost more than 24" TN junks (and few VA El cheapos) and probably need "supplementary budget".
Then there should be at least many older non-TN models in 20" size and if you don't necessarily need widescreen (for secondary use like movie watching) you might want to check also 1600x1200 resolution 4:3 displays.
BAH!
So confusing. Seriously!
I think I made up my mind.
Either 2 x Samsung 215TW OR 1 x NEC LCD2690
I've finally broke it down to these 2. Just can't find anything for under $1000. I'll have to wait a bit before I can purchse either option...but i'm not changing my mind anything =)
