Comixbooks
- Jun 7, 2008
You can put it in to words: Low distortionI haven't auditioned those particular headphones, but I do happen to have some planar-magnetic computer speakers and noted that they have a lot of that clarity I missed from my old Stax Lambda setups, without the delicate fragility of electrostatic drivers or their expensive, specialized amps.
I'm a firm believer of planar drivers, regardless of the driving force (magnetic or static) used. The sense of clarity is something I can't put into words; you'll have to audition it for yourself to truly understand.
There are, they tend to have more issues though. There are different issues with distortion in speakers (in part just because of how driver much movement you need a bass frequencies) and things like dispersion patterns become a thing so in general you find that the very best of the best speakers are still dynamic drivers. Things like the Genelec 8361A or JBL M2.Wow didn't even know there were speakers.
Just note that some lower-end planar driver headphones only have a magnet on one side of the diaphragm, not both in a sort of push-pull sandwich. This presumably would mean lower sound quality, but also lower weight and perhaps more comfort.
I recommend getting a better amp.Funny that you mention stax. I had a pair of Lambda normal bias, Ps audio modded dac and a sound quest SQ-84 amp and SRD-7 energizer. Amp used 6V6 tubes. Damnnnn that was a great sounding setup.
Now Iuse a Sonco usb dac, Emotiva Basx A-100 amp which, like the SQ-84, allows you to use the speaker amps power in the headphone jack. So my hifiman se560s I got for cheap rumble and are clear as a bell. Great for gaming and most anything else. A bit bright at times but I can always upgrade to the XS.
Not all Planar are the same.I have Fostex T50RP MK3, and while I like them... They are an absolute pain to drive properly... my vintage Sony TA-E77ESD preamp can do it.... however they sound terrible (too little power) with my FiiO E09K as well as my creek OBH-11. both of which can handle my DT880 250ohms or my HD6XX headphones fine....
If going planar make sure you have your amp situation sorted...also note that planar and tube amps do not get along very well.
