Hey everyone,
Not entirely sure if I should post this in processors, motherboards, or what, so I'm shooting here.
I'm installing an Intel Q6600 processor on my Gigabyte GA-P35-DS3L motherboard. I know I have the processor aligned correctly in the socket (Arrow to arrow, notch to notch), but when I put the metal face bracket down and try to lock the lever, it's clear that I need to put a lot of force right on the processor to do so. Just a small amount of force will yield little crunching sounds (Presumably from the metal pins underneath?)
It this normal? I was literally sweating it out for a little while there. The last thing I want is a $250 piece of debris.
Thanks in advance.
Edit: And yes, I fucked the topic title up. Meant to say placing Q6600 on motherboard. Chalk it up to the case of the flu I have right now.
Thanks in advance.
