Yup. I've got 3 boxen I start by shorting out the pins with a jack knife.Kroz said:so that is the problem, i need to short it for a sec, not indefinatly...
Kroz said:So I have build a computer in a box to fold but I have run into a problem, how do I turn it on?? I have no switch like I would in a case. I have tried to jumper the pwr switch jumpers with no luck...
Relic, king of the pizza boxen. All hail theerelic said:As was previously stated, the power on signal requires only a momemtary short.
Other important things yo consider when building "boxen in a box".
1. Papa John's extra pepperoni boxen OC better.
2. Eat the pizza before you build the box.
3. Using water cooling in pizza boxen may open a fundamental rift in the space-time continuum and end the universe as we know in. If you need to liquid cool these boxes, use BEER. (I know, I know..this is common sense...but it needs to be said just in case)
4. Always clearly mark DC pizza boxen. The potential physical damage from drunken friends opening the box and munching on a video card is cause for alarm. This could easily short out the motherboard and the potential loss of DCing time while driving your friend to the emergency room is devastating. Always remember the fundamentals of triage. Your friend has only a few broken teath, but the boxen is near death....fix the boxen first.
gnewbury said:Finally Instructions!!
I kept on skipping step 2 and had a LOAD of problems, especially with the double cheese pizzas!
thermal greaseOC oil.
No.compslckr said:thermal grease![]()
Tigerbiten said:Don't put the pizza's on the heat sinks to keep them warm.
It will void your warrenty.
Kroz said:Question answered, can someone lock this thread as it has got just a tad off topic...
