Pixio PX329 32 inch 165Hz WQHD 2560 x 1440 w/ FreeSync
Discussion in 'Displays' started by Gatecrasher3000, Aug 8, 2018.
  1. Gatecrasher3000
    Gatecrasher3000 Limp Gawd
    259
    Mar 18, 2013
  2. Armenius
    Armenius [H]ardForum Junkie
    15,489
    Jan 28, 2014
    Have heard that Pixio puts out poor quality stuff. You get what you pay for.
  3. Mokkat
    Mokkat [H]ard|Gawd
    1,162
    Sep 24, 2006
    Typical budget monitor stuff. Usually the panel will be good, for example this one as it is almost certainly the same one used in the LG 32GK850G. But then you have the issue of Pixio designing and advertising it as 165hz, which this VA panel probably isn't really fast enough for, and I wouldn't expect much from the build quality, color accuracy out of the box and OSD design.
  4. Parja
    Parja [H]ardForum Junkie
    11,491
    Oct 4, 2002
    Got one of these on order to try out with "G-sync for FreeSync monitors". Anybody try expanding the upper range on FreeSync with CRU?
