pixel shaders article .... ps3.0
Grazie - this is a nice summary write-up on what shaders are, do, how they work, et cetera . . . good summary, thanks for the link :) .
Uhmm, that's actually fairly crappy summary of shaders, and the features that the various shader models allow. Plus, it contains some significant bits of misinformation (the one that flies out at me is the instruction count summary on the final page). I'll write up a summary of points they missed or were wrong about later.
Nice find. A bit summarized and left out some stuff, but it's a good one for explaining things in a nutshell.
it looks as if 1.4 and 2.0 are dead from hereon in, with 1.1 being the legacy path. This is exacerbated by the fact that Xbox is 1.1 and Xbox 360 is 3.0 - 2.x isn't anywhere on the console scene
This is the first explanation i've heard on why SplinterCell only supported PS1.1 and 3.0 :)
Actually that explanation was given back in 2004 during a B3D interview :)
Indeed, there are a few small errors, such as that only 3.0 shaders allow floating point precision.
But I guess the idea is clear, and unless you actually want to program shaders yourself, the minor details don't really matter. All the info is in the DirectX SDK anyway.
Shows how much i missed don't it :p See, even these articles can be useful sometimes :D
Yeah, the max shader length for SM3.0 is 65,535 instructions, not 32,000.
The main differences between them can be summed up fairly easily. Each revision has allowed for the length of a shader - the number of separate instructions that can be executed - to be increased, allowing for increasingly complex and sophisticated effects to be created. The ways in which the programmes can be written has also improved - the 1.1 specification provides just for straight code, whilst the 2.x revisions allow for some looping to take please to repeat lines of code. The 3.0 model allows for dynamic branching along the lines of if -> then statements in code. Increasingly smooth techniques for cutting the length of code have been made, allowing for speed improvements. Possibly the biggest single change between the 2.x and 3.0 specification is the addition of Vertex texture lookups in 3.0, which allows for displacement mapping to take place.
The only notable jumps in shader versions are from 1.x to 2.x. 1.x shaders were in general VERY limited, with few registers (I think it was 8x4 floats?), few instruction slots and not many functions (yay, we can, um, add, multiply, move...). SM2.0 was literally a revolution by comparison. Suddenly, devs could handle a lot more data, and do more with the data, and shaders actually became USEFUL. SM2.x and SM3.0 however, offered little more potential. Yes, registers, instructions and instruction counts rose a lot more, but there are few algorithms that, image quality wise, 2.0 could not do. Also, vertex texture lookups are not that great, imo, and loops do not work as well as many people would like them to. The image quality that branching brings could even be simulated on SM2.0 hardware, as evidenced by the fact that the HLSL compiler can do if statements just fine when compiling to an SM2.0 target. Basically, the jump to SM2.x and SM3.0 aren't all that bit-tech cracks it up to be, and they seem to hail it as something that is blowing the minds of graphics programmers, while in the real world there is actually a small debate over how useful SM3.0's features really are.
The higher colour precision means that the 3.0 path allows High Dynamic Range lighting, which presents a much more varied colour range on your screen. Brights are brighter and darks are darker, with the overall experience appearing far less bland. There is a big performance hit for enabling it, due to the extra precision on the mathematical calculations, but the next generation of hardware, such as the GeForce 7800 GTX, is far more competent at it.
What higher colour precision? 24-bits is STILL enough for any graphics algorithm out there. The HDR support is an entirely seperate feature that came with SM2.0 cards (9x00 and FX). The 3.0 path is able to use HDR because so many more instructions are required for all of the post process effects (bloom, glare, exposure) that people associate HDR with. Also, it is primarily because of those effects that performance suffers, not just because floating point render targets are suddenly being used.
because 3.0 is more efficient.
No, fewer passes are required on SM3.0 hardware because SM1.1 is so damn limited.
The Soft shadows obviously allow for better quality shadows - this is partly achieved by having the 3.0 shadow shader use dynamic branching to execute quicker - dynamic branching being part of the 3.0 spec.
I'd be SHOCKED if the soft shadows come in because of the dynamic branching. I haven't seen SC:CT myself, but I can bet that it's just because they need the increased instruction count that SM3.0 provides. It's also likely that SM2.x could run those shaders A-OK as well.
Crucially, the next DirectX specification, WGF, calls for a unified specification for pixel and vertex shaders, so that the two can be used interchangeably at a software level.
That's only half right. The so-called shader unification of "SM4.0" is just because finally vertex and pixel shaders will have the EXACT same capabilities. Hence, it almost follows directly that a shader core could be used for vertex or pixel usage.
It sports a next-generation user interface, codenamed Aero,
Huh? What happened to Avalon?
*BZZZZT* WRONG! http://msdn.microsoft.com/library/e...aders/pixelshaders/pixelshaderdifferences.asp The top of the page there lists the instruction counts for each shader model (vertex instruction counts are basically right, though). Dynamic branching? Yeah, woo, like I said earlier, so what? Backface register? All that contains right now is a freakin' sign, and I can't even think of ANY practical use for it (two lighting calcs in one pass couldn't be further from the truth). Maybe occlusion queries on the PS? Colour depth? Wrong again, SM2.0 AND SM3.0 cards support 16-bit (per channel) floating point targets, not just 8-bit or 32-bit like bit-tech thinks. Nested looping? Yay, now I can do some loops where the different variable I access is a vertex input register! It's so useless, just do it the Crytek way and just make some different shaders that behave like loops!
*hits preview* Damn, that turned out to be pretty long. Oh well, at least you know that bit-tech editors just glance over information they don't really know and make it seem like they know it.
Edit: Whoops, missed one point. 32-bit per channel FP targets DO exist, I forget what cards support them. I know I'm using a single-channel 32-bit FP target at home for my shadowing demo on my X800Pro, so Xx00 and 6x00 cards probably support them, assuming 9x00 and FX don't.
Actually, the post-processing is done in a separate pass after the initial image is rendered. With more instructions it's easier to do larger filters in a single pass, but it's not strictly required (multipassing with a single fullscreen quad is not all that expensive, usually not the bottleneck).
The main difference is that (in practice) SM3.0 cards have floating point alphablending, which makes it really easy and efficient to handle translucent surfaces in a HDR-image.
It's not impossible without it, but it is just harder to do, and less efficient.
Two-sided lighting ofcourse. You apply the sign to the normalvector, so backfaces can be lit properly aswell. Normally you'd have to double the backface geometry and send it twice, with the proper normal for each side, or alternatively render the geometry twice, first with a frontface shader and backface culling, then with a backface shader and frontface culling. Not a good idea in geometry-limited situations.
9x00 supports 32-bit per channel though generic Direct3D formats. FX lacks proper texture address wrapping logic for FP targets, so it only supports some proprietary formats, but by using those you can still render to 16 and 32-bit per channel surfaces.
And that's useful how? Backfaces aren't supposed to be visible to the user, or if you're using it to light it up, they're not supposed to be lit. The lighting demo I made at home runs awesomely without any tweaks to backfaces or anything.
Think of objects with holes in them, or translucent objects, where the surface can be viewed from both sides.
Heck, even something as simple as a wall or a tablecloth could be viewed from both sides.
Just any non-convex, non two-manifold object you can think of, really.
