(posting more broadly than just the L2410NM thread, as maybe others have insight on this problem).
I just picked up a westinghouse LM2410NM earliet today. Once I got it calibrated I was really happy with it, especially the color.
Then I brought up Adobe LIghtroom and looked at some photographs. I noticed on some pictures, in darker areas, pixels would flash erratically from dark to bright white. The more I use the monitor the less it happens (maybe 1 out of 50 photographs vs 1 out of 5 initiailly), but it is still disheartening.
The monitor is connected to a macbook pro with a ~3 year old dvi -> hdmi cable from pacific cable. When I connected via D-SUB I wasn't able to reproduce the problem.
I had a 2005FPW before this and never had this problem. My guess is that either the monitor is bad or I have a bad cable? It doesn't seem like a cable would cause this, since a digital signal either works correctly or not at all right?
I bought from Best Buy, so exchanging for a new one is not a huge hassle. That said, apart from this issue I have no buzzing or dead pixels, so I'm reluctant to "roll the dice again". Maybe it's worth trying a new cable?
(Firmware 1.1 btw)
(Firmware 1.1 btw)
