Hello all, I purchased some Pixel Buds earlier this month, as I liked the way they looked, and I liked the wire between the two buds. I have been searching for a good wireless solution for a while.
I received my Pixel buds and I enjoy the fit, but when it is paired with the iPhone, the sound is very underwhelming. Even with the Volume at MAX, it doesn't sound loud at all. I paired it with my friends Pixel 2 today, and they sounded much better, most likely because they are both Google products.
To test, I ended up purchasing a pair of AirPods, and they sound much cleaner(Not as good of bass as the Pixel Buds), but they also have a louder volume.
I'm not sure if I should try anything else with the Pixel buds or return them.
Any insight or suggestions would be welcome.
Side note: Please don't post if you are going to start an Android vs iPhone flame war
