Ok, the office I work in is planning to obtain a PIX 525. I was wondering where in the network it should be installed... Right now we have two T1's for internet access, a DMZ segment, and an internal segment as well. Also, our current configuration requires that packets can be routed out the same interface then came in on. Where in the network should the PIX go? Should both WAN lines connect into it (along with DMZ and LAN) and then have an external router for the lan segment (allowing packets to be routed out thier incoming interface)? Not sure where to go with this one...
