Pipes..
Cryptic
I have a eVGA 6800GT. I'm running it stock, but heard there were 4 more pipes to be unlocked. How do I do this? When I go into the video card settings by going through the display>advanced> blah blah there is nothing to overclock the card...do I have to dl riva tuner? Was just wondering how to unlock the other 4 pipes. Thanks in advance.
thats only with 6800 NU's and LE's.
your 4 extra pipes are already unlocked :p
yeah the GT runs on a 16 pipe interface where as the nu and \le's run on 12 pipes. so dont worry about it, but if you could get 20 pipes then thats awesome lol.
To overclcok the videocard with the Nvidia drivers, you have to add certain reg. values. After adding those Reg. values you will see additional options in the advanced menu screen.
(I just enter the Advanced Menu selection by- right click on desktop>>select Nvidia Display)
The easy way to add those Reg. Values, use coolbits.
Dl Link-
http://downloads.guru3d.com/download.php?det=201
And here is a whole list of OC utilities-
http://downloads.guru3d.com/download.php?id=13
