scottatwittenberg
- Apr 10, 2002
ok... my temp computer in my sig now has a WD100 it is a 10 gig western digital... the computer i am using right now has the exact same hard drive... but on this computer it runs in Ultra DMA mode 1... at home i can only get it to run in PIO mode...
i went into device manager and clicked properties on the HD controllers.. set them to "DMA if available".. it changed my 4 gig seagate to UDMA 2.. but my WD100 still shows PIO..
i checked all through my bios and didn't see anything that mentioned DMA except one thing.. which i changed from 3 to 1 and it still doesn't make a difference... i am using 80 pin cables in my computer at home... the one here only has the 40 pin cables...
so does anyone know what is causing this? i read that PIO mode will make a computer run much slower.
thanks
scott
thanks
scott
