pio mode enabled and won't turn off
KingTKS
ok i bought this board
RS480M2-IL its the microatx msi 939 pci-e board for my antec aria
wouldn't burn cds and cpu utilization was maxed when ripping data off cds
so i go to device manager and sure enough on the ide controller pio mode is enabled
so i set it to dma if available.
i restart and the option dma if available is still selected but it says below current trasfere mode: POI MODE
I'm like CRAP
so i went into the bios and i didnt' understand it.
there were bunch of pio things and dma stuff. all the dma stuff was enabled and the pio was on auto (only other option was pio mode 1-4)
so i have no clue what to do
please help me someone
thanks
trevor
Yep, installing the latest drivers won't fix it completely, you have to uninstall the IDE channel that is causing the problem. When you reboot, it should redetect the channel and DMA should be enabled.
I've had this happen a couple of times, and uninstalling the IDE channel fixes it every time.
i didn't think to uninstall the ide controller
it fixed it to udma4
thanks a lot
