Pinnacle Ridge Threadrippers incoming
Discussion in 'AMD Processors' started by gigaxtreme1, May 14, 2018.
  1. Epyon
    Epyon Gawd
    810
    Oct 25, 2001
    I hope to see 24 cores with 4.0 clocks by 2020. 48 threads at those clocks would be sweet. 32 cores at those speeds would be really nice if it can be done.
  2. DuronBurgerMan
    DuronBurgerMan [H]ard|Gawd
    1,117
    Mar 13, 2017
    You might get that in 2019 if the rumors about a 6 core CCX for Zen2 are true.
    N4CR likes this.
  3. _mockingbird
    _mockingbird Gawd
    913
    Feb 20, 2017
    ...probably $1500 if AMD does release one
  4. Epyon
    Epyon Gawd
    810
    Oct 25, 2001
    Keyshot would run so smooth it would be better then running duel xeon. I would pay $2000 for a chip like that.
  5. juanrga
    juanrga Pro-Intel / Anti-AMD Just FYI
    2,412
    Feb 22, 2017
    I am fully convinced that Zen2 will increase the core count. If that is achieved by introducing a new 6-core CCX or by adding another 4-core CCX to the die I don't know. But moar cores in a 7nm? Sure.
    Shadowed, N4CR and DuronBurgerMan like this.
  6. prne10
    prne10 Limp Gawd
    222
    Oct 26, 2005
    Is there an official definition for what "sampling" means in this context?
  7. gigaxtreme1
    gigaxtreme1 2[H]4U
    3,432
    Oct 1, 2002
    Last year Dell had initial launch for OEM exclusivity. Samples appeared on Sisoft database as per Videocardz. The chips go through testing and qualification prior to launch as systems are designed and tested.
  8. juanrga
    2,412
    Feb 22, 2017
    It means sending samples to partners for the purpose of testing motherboards, software,... Probably AMD is sending qualification samples or even pre-production samples.
