Pink Componets?
itsjared
I'm doing a quick mod-job of an old case laying around, I thought pink and black would be good since it's close to valentine's - plus my sister has been needing that Christmas present.
I'm doing matte black for the case frame and a cool heart design in pink on a black gloss side panel. I'm looking to keep the inside light and airy and was curious to see if anyone know of any white or pink (light or dark) parts that might look good.
I'm trying to do some sleeving but can't seem to find anythin in pink, closest I get is UV red. Anyone know how that might look under a white cathode or any other suggestions?
UV Red usually turns out pink anyways to be completely honest. Especially the heatshrink, very pink. Purple would probably be easier to find parts in however.
Not aware of any components (I'm guessing you mean video cards, etc?) that are white or pink in color. Green seems to be the most common card material color.
I do know that at one time I saw UV paint that you could paint the inside of the case with, but don't recall if it was brushed on or sprayed. Hold on....
UV paint at Xoxide
available in spray or brush style! Only have blue, green & red, but the red might be pale enough to pass for pink. :)
Not sure what size fans your case has, but they have this UV red fan as well, that looks awfully pink to me. They also have this LED flash programmable fan that's red lettered, but would be cool (tho expensive!!).
Finally this "liquid neon" cathode light also looks fairly pink in color.
Hope that helps! :cool:
Review says that cathode is pink. Nothing on the fan though. Good luck on finding pink. You may be painting I think. I looked when I was building my wifes. Settled on the inwin allure case. She loves it. Though its a bit pricey.
u can find a pink keyboard and mouse. and i think they have uv covers. pink headsets, usb hubs, cables etc. red but look pink
http://www.frozencpu.com/products/5...ED_92mm_Fan_-_Red_ACR-BF4678.html?id=U5sriwBu
also red , but look pink
http://www.newegg.com/Product/Product.aspx?Item=N82E16835200050
http://www.newegg.com/Product/Product.aspx?Item=N82E16822211018&cm_re=pink-_-22-211-018-_-Product+
good luck. u might find some hello kitty stuff for it too, somebody made one for their kid, and they make hello kitty everything.
