Pin modding
Doubl3KiLL
Hey, Im pin moding my DLT3C and I was wondering if you can just push the wire into the correct holes on the ZIF socket and push the OPGA onto them and connect them that way? Im only on the first connection, but it would be a crapload easier to do it that way. Thanks
