Pin Assignments for SB Live!
Gen.Viper
Hey, I'm making a HTPC mod, and I have a slight problem. I plan on using my old SB Live! X-Gamer to provide audio out for the time being, and need to know (in plain english) what the pin assignments for the AUD_EXT connector on the back of the card are. I at least plan on using a volume control knob, a mic in, and headphone in. This is a link to the pinouts from the creative website, but they may as well not be there at all for all the good they do me. :( Does anyone know what the assignments are, in some way that could be a bit more meaningful? I hear Mister X has answered a few of these type threads, but I couldn't find any of them. Thanks for the help!
Well, the pinouts in the user manual are the same as those from the link. And they're not terribly helpful to try and figure out what pins to hook up mic in, headphones, etc. :-/
If anyone might have some idea what all the technical gibberish might mean in terms of that, it would be appreciated.
And thanks for the info Mister X :)
That is because there are no analog conenctors on that header.... and as such you cannot connect your front pannel IOs to it like that
