Pin Asignments
John-K
I need Pin Assignments for USB 2 and Firewire -- But my pins don't match the specifications I've found on the web. Specifically, the Silverstone TJ05 case's pins don't match up with what I've seen. And -- belive it or not -- their e-mail address is invalid.
Can anyone provide any references?
The labels on the connectors for cases usually don't match excatly what's on your motherboard (for example, VCC connects to USB +5V and GND connects to GROUND) . If you take some time to study the pins from your case and on your motherboard, it will not be difficult to figure out which goes where.
It would also be helpful if you can tell us what motherboard you are using.
