Your mission:
To give me upgrade options for my tired gaming PC but keep the cost below $600 (tax & shipping incl.). I play WoW and FPS shooters and typically watch 6-8GB blu-rap rips on my smaller screen while playing WoW.
Current Hardware
CPU: Intel Core2Duo E6550 @ 2.7GHz
Mobo: Gigabyte EP45-UD3R Rev1
RAM: 8GB (4x2GB) G-Skill DDR2 (F2-8500CL5-2GBPK)
Video: BFG 8800GT OC
PSU: PCP&C 750W Silencer
HD: WD Black 640GB
Case: CM 690 II Advanced
Displays: Main - Dell 2407WFP (1920x1200)
Secondary - Sony SDM-HS94P (1280x1024)
Caveats:
- I'd prefer known hardware combinations that work. Also, I would prefer to re-use anything I can (ie HD, case, PSU)
- CPU - AMD or Intel I really don't care, I'm open to either.
- Video - I'm looking at a minimum of the GTX460 1GB or 5850, in that range.
- RAM - I have 4x1GB of DDR3 1066 I can use to hold me off until March if it means I can go with a better CPU or mobo now.
Begin!
(Specific form fields from sticky to be in compliance.)
Gaming - WoW and FPS. I do frequently like to watch 6-8GB blu--ray rips on my 2nd monitor while playing WoW. As of now I have to play them in a window, my current system can't handle them fullscreen while WoW is running.
$600, not too worried about tax and shipping.
3) Where do you live?
US
4) What exact parts do you need for that budget? CPU, RAM, case, etc. "Everything" is not a valid answer. Please list out all the parts you'll need.
CPU, Mobo, Videocard and maybe RAM (if the DDR3 1066 I have won't work).
Case, PSU, Monitors, Heatsink, RAM9 (if I can use DDR3 1066)
6) Will you be overclocking?
no
24" 1920x1200 (main for games) and 19" 1280x1024 (secondary for web)
Parts for X-mas
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
SLI, would be nice to have, but not mandatory
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? 32bit or 64bit?
64-bit Windows Home Premium
