Pictures Blocked
l3ender
Hi, I frequently view [H] just to find that some (not all) of the pictures in threads never load. I am using Zone Alarm Pro, and I have added this site to the "safe list", but to no avail. If I disable ZAP, the pictures show, is there something else I could do?
As you could imagine, this is very annoying, and I would not like to be browsing the internet without it enabled.
TIA.
The pictures are not hosted on this site. They are hosted externaly. By allowing this site, you may still be blocking the site that the picture is hosted on.
Well here's an experiment for you. I'm hosting the pic below on a site I'm 100% positive you don't have blocked:
Does it show up? If yes, then you probably have imageshack and the like blocked; otherwise it's a more universal issue. You could have also unchecked the "show images" button in your user panel.
This isn't a forum problem on our end...as jbog91 stated, the images in the threads aren't hosted here, but on private hosting sites which are up and down at times.
That picture shows up. And I've unblocked Imageshack, can you think of any other ones that are universal, and thus I should block them? It's odd because it's not all of them.
Your mom might have some parental control on for you. :) jk
Nope.
You can always right click the red x and see what the properties are pointing to.
