Picking a CPU for first DICE run
Cecil
Have a EP45C-UD3R coming to me, and a DICE pot. Have 2x1gb OCZ 1200Mhz 5-5-5-15 ram. Trying to find a good CPU tha will rack me up a bunch of hwbot points. Thinking of getting a high end Celeron D and aiming for 7.5Ghz+, since there are plety there at 8Ghz+, and they are cheap.
For daily use however, I have a nice water setup, and would like something actually quick. E7400 is $100 at microcenter, and should get some nice clocks, but only enough to net me ~15 points if Im lucky.
Any ideas anyone? Will probably grab a celeron to toy with anyway, and practise on.
Cecil you seem like a very intelligent young man, and future epic warrior on the Bot.
Have you looked into the 352 at all? Also sometimes you can pull a 775 celeron lot off ebay for cheap
Correct, I have a shop 5min from me that sells DICE.
Ive been looking on ebay, and can grab a 356 for $28 shipped buy it now. Put a $15 bid on a 352 though, waiting for it to end before I consider the other one.
Im trying to find a nice C2D/C2Q however, to use daily (and torture as well). Ill be at Microcenter next weekend (with a fresh pay :D ) and am trying to decide if I should get one there or not. They have,
E5200 $60ish
E7400 $100 (may have gone up to $110)
Q9400 $160
Or if I should look around at something else used.
Gosh, I would like to learn how to overclock that old stuff someday too. Good luck with that bot place Cecil, you seem to know alot about how to get points.:p
Rom, is that like romulan? ;) or Read only memory?
Cecil, great prices your find there mate
Im not too worried on the daily use chip. Will probably only have this setup a couple weeks anyway (will most likely keep it as a back up though, and to test other chips that come my way). Then go back to i7. Either a 920 D0, or 950 depending on how money will be.
Im thinking E6300 might be a decent cheap chip for good clocks. Any thoughts?
That or E5400 for the 13.5 multi.
Roms like slaughtered 6 billion Vulcans in the latest StarTrek movie Roms....tyvm:p
Is there no other c2d's to try before going to c2Q's? or dumb question?
My bench skills are still growing.:rolleyes:
Im getting the celeron to break in to the top 100 all time CPU-Z scores (hopefully).
Then Id like a decent CPU for daily use under water, hopefully that doesnt cost much.
Trying to decide between,
E5400
E6300
E7400
E7600
Q9400
Celerons keep getting taken out of my grasp, grr. Will hunt one down soon though.
That ram won't run on that board so i'm sorry you already ordered it. The board you chose is DDR3. You should have gotten the EP45-UD3R which uses DDR2, but I'm not sure how it's going to take to that OCZ.. it's kinda picky. http://www.newegg.com/Product/Product.aspx?Item=N82E16813128359
Lol, it uses DDR2 and DDR3.
e8500 e0. if you look around you can find one for $145 - $150 shipped to lower 48 states.
For $150, Id rather a quad since its for daily use, and media, not so much gaming.
Just got a Celeron 352 for $35 shipped. Hope its a good clocker.
