Sounds a bit tough..
On newegg your choices are..
7600GS - $95 after mail in rebate
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130076
You're probably better off saving for a 7600GS. The x800gto isn't too bad but it's open box and I'm not sure if you will want that.
What are you system specs ?
-Raven
MSI KT4AV
AMD Athlon XP @ 1.13ghz(Looking to upgrade)
768mb PC2100(Looking to upgrade)
ATI Radeon 9000(Looking to upgrade)
Couple 100 gigs of HDD
Running OS: Windows Vista Ultimate 32bit
Thanks for the help thus far
-Jay
