Physical mode RDM LUN expansion issue
RESTfulADI
I recently had to grow physical mode RDM LUN connected to two 2008R2 guests running a SQL Server AG, the client already had this setup so I had no choice really. I grew it in Unisphere (concatenated metalun) but after HBA rescan my hosts still saw the original size... Double checked LUN properties, everything looked good. I rebooted one of the hosts (one not hosting the two guests in question), still no dice. Opened a ticket and they want me to power down both guests and try another rescan or reboot, the engineer said the SQL cluster OS' may be "locking" the LUN and preventing ESXi from recognizing the new size.
I've never heard of this problem before and I can't power down both nodes any time soon, the SQL cluster runs a critical DB and approval/scheduling for an outage will take a couple of weeks at least. This vSphere cluster is running 4.1 if that helps.
Any ideas?
So, that's shens for the lock - the reservation is held, but by one of the hosts the guest is on. Rescanning both - one should pick it up
That being said, VC lies - go to the CLI, see if it is actually showing up for the hosts, and VC just hasn't caught on yet.
Still shows original size, the new size of the metalun is 208GB, this is identical on both hosts where one of the guests are running. Is this what you wanted me to check?
Code:
~ # esxcfg-scsidevs -l | grep -A 10 naa.60060160052129002abc0a2a01ace011
   Device Type: Direct-Access
   Display Name: DGC Fibre Channel Disk (naa.60060160052129002abc0a2a01ace011)
   Multipath Plugin: NMP
   Console Device: /vmfs/devices/disks/naa.60060160052129002abc0a2a01ace011
   Devfs Path: /vmfs/devices/disks/naa.60060160052129002abc0a2a01ace011
   Vendor: DGC       Model: RAID 10           Revis: 0430
   SCSI Level: 4  Is Pseudo: false Status: on
   Is RDM Capable: true  Is Removable: false
   Is Local: false
   Other Names:
      vml.02000d000060060160052129002abc0a2a01ace011524149442031
   VAAI Status: unknown
Yep. From both hosts, do:
esxcfg-rescan -A
vmkfstools -V
then run that again. If it doesn't work, snag me a vm-support.
I ran the commands and nothing changed. I have the support files, where would you like me to send them?
Thanks for the help.
