Php Mysqli SUM not working?
boycee
I think I'm going mad, but query is not returning any values, only nulls.
The query is fine and works fine in phpmyadmin, so the implementation must be off? Or it's a bug?
Any takers?
Code:
SELECT SUM( colCount ) AS re
FROM (
SELECT COUNT( colPage ) AS colCount
FROM browserData b
GROUP BY colPage
ORDER BY colCount DESC
LIMIT 0 , 2
)table1
Code:
		private function selectQuery($query)
			$statement = $this->_connection->prepare($query);
			if($statement == null)
			  die("Bad SQL Statement");
			$statement->execute();
            $meta = $statement->result_metadata();
            while ($field = $meta->fetch_field())
                $params[] = &$row[$field->name];
            call_user_func_array(array($statement, 'bind_result'), $params);
            while ($statement->fetch())
                echo '<br/><br/><br/>';
                foreach($row as $key => $val)
                    echo 'Field:' . $key . '<br/>';
                    $c[$key] = $val;
                $result[] = $c;
            $statement->close();
            return $result;
