Photoshop hard drives
vidoprof
SO I am noticing that my Rig is a little slow (Q6600, 4 gigs ram) which is nuts.
I use photoshop and Corel PhotoImpact and when I open a few files it really starts to bog down. I am running XP Pro and the OS is on a 40 Gig Drive (Samsung 7200.7 IDE drive) I believe (cause I couldn't get the SATA drives to work as the OS drive (I don't know how) this might be one of my bottle necks.
Also I have the scratch disk on my data drive (Samsung 7200.10 500gb drive).
Would this be my issue? How could I possibly set it up and get MUCH better performance. I don't mind redoing the entire system at all but how would i get where I need to be?
I ALSO don't mind spending any amount to get it to perform better. I am almost at the point where I will buy another machine at $3k to get it to where I need to be.
Thanks
Ryan
some suggestions:
vista 64 bit os and up the ram to 8gb
raptor for os drive
raid 0 array for scrach disk, the more drives in the raid 0 the better something like 2-3 x raptor would be good
make sure to set static page file size instead of letting windows allocate it on the fly
I would go with XP 64 bit. And of course up the Ram to 8 Gig.
You can up the FSB speed on your MOBO and set the mulitplier lower to increase the data throughput going to and from the processor.
Your 7200.7 drive is a major bottleneck on your system. I would get a new MOBO, and an separate Raid controller and Raid 0 a couple of Raptors for the OS drive, and Raid 0 a couple more raptors for the scratch drive.
If money is truly no object, you could always Raid 0 a couple of Mtron SSD drives for your scratch disk. That would be smokin fast. How does 150 gb/s with .1ms access speed sound.
Don
I don't think i need a new MOBO. I just got the thing when I built this system. I can totally get a faster OS drive and several faster drives for the scratch for sure.
Problem is that i dont know how to install XP on a sata drive. I tried it once with some software (nlite maybe) and it didn't work out.
XP 64 bit, I still have to look into that and see if I have any driver issues. I run a lot of software for photography and not sure if it runs on that version. I know XP Pro is rock solid though. I would love 8 gigs of ram.
RYan
I would seriously consider Mtron SSD drives. I will have to look into them. maybe a 32 for the OS and then a 16 for the scratch disk
if you're going to go for 64 bit os go for vista, a lot better support and drivers then for xp 64, I don't know about other photo software but photoshop cs3 works perfectly on vista 64, I use it and don't have any issues.
As for installing the xp os on sata drive you need to hit f6 during the start of installation and provide it with a floppy with drivers for your sata controller. There is also a way to slipstream storage drivers into the xp install cd, If you installing vista you don't have to worry about it, the drivers are built in.
I have been installing XP on Sata drives for years with no problems and no additional drivers needed. Just boot from the XP CD and it will list the drives that it finds. I find it best to have just your boot drive connected to the computer when you install Windows to prevent drive letter issues down the road.
If you want to install on a Raid controller, you will prolly need a driver diskette. Just look on the drivers cd that came with your MOBO, and there should be an option to make the diskette you would need. I think on my Asus driver CD, if you boot from the CD, it will give you a nice little menu to make the driver diskette. If it is not on the driver cd, then just go the the MOBO manufacturers web site in the downloads or support section, and you should be able to find it there.
The SSD drives are still hideously expensive. But if absolute speed is your thing, 2 or 3 in a Raid 0 can't be beat right now.
You could always dual boot your system with XP and Vista 64. Instructions are easily found on the net on how to do it. That way when you are working on a big project, just reboot into Vista 64 and utilize 8 gig of RAM.
I am currently dual boot XP and Vista on my system with no problems.
Don
I think Vista 64-bit is the way to go for what you are after. Much less likelihood of not being able to install a hard drive and being able to use extra memory (8gb). I use Photoshop CS3 all the time on it without any problems. In fact, I've run in to very few problems with program compatibility with it that I care about. A few EA games don't work for me, but that's not a big deal to me. It's a rock-solid OS from what I have experienced. The other thing is that Vista tends to do a little better job of managing memory than xp as well as a better job of utilizing more cores, and yours is a quad.
The system I run has two 160GB Seagate drives in RAID 0 for my system drive and a Western Digital 640GB drive (fast fast fast) for data. I also have a WD 400GB drive for backup. I use the RAID 0, 400 and 640 for scratch disks and I have the q6600 and 8GB of ram. It flat out screams, especially for photoshop stuff. One other thing in photoshop is that when you are using 8GB of ram, remember to max out the memory usage of photoshop in the preferences (go to 100% there).
Questions:
Photoshop is not currently a 64-bit app... but can it access all 8gb of ram if used with Vista 64? And what differences will we see when Photoshop does become a 64-bit app?
Ok well I don't know if all of my software will work.
I currently use
Express Digital Core edition for my online galleries (they said I should be fine)
Breezebrowser Pro
Downloader Pro
PS CS3
Shinko Printer for printing 2145 (not sure if the driver works on Vista 64 bit, but I will check.
That's about it for now.
I just don't KNOW Vista like I know XP so it bothers me a bit if something goes wrong.
Ryan
I guess I could always dual boot the OS.
So how would that work?? On the boot / OS drive put Vista 64 and XP Pro and then on another HD put all the programs that I will run in either environment?
Thanks
Dual booting is easy.
For your situation, I would pick up a 150 gig Raptor, install XP on a partition taking up half of the drive. Then install Vista 64 on the remaining space on the drive. Actual instructions here.
If you are starting with a clean hard disk, then you can skip the first part where it talks about changing the partition size to make room for Vista.
Then add a fast storage drive to hold your data, like a Seagate 7200.11. You could still add a couple of SSD drives in a Raid0 to really boost your performance.
You will need to do a separate install of each program in each OS, but you will be able to work with your data on either install.
Don
Don Don.
Thanks for the instructions. I will defintely be doing this sometime in the next 2 weeks.
I am STILL going to be buying a new rig though now that my business partner wants mine, so I am submitting a thread on a new rig. Under general computing
Ryan
Here is an interesting post from Adobe's blog on their website about PS and memory usage.
Running the 32 bit version of PS in Vista 64 with maxed out memory seems to be the way to go.
I have heard on other sites that a 64 bit version of PS is in the works, but the performance gain over the above setup would be minimal.
Don
I use PS daily for my shop. I work with billboard and full vehicle wraps - think PSB (PSD files limit you on size) files in excess of 4GB. I've tried it all. The only thing that really made a BIG impact on speed was using a ramdrive. Even with 64GB of RAM in your box PS is going to be sluggish when working on large or lots of images open at once. On the box in my sig (you do not need to go that far) I have 12GB of the ram configured as a ramdrive using the paid version of qSoft RamDisk. That appears to Windows as another drive - that is my PS scratch disk. Yes loading images from a 15,000 RPM SAS drive helps also but not nearly as much as the ramdrive. I still end up caching though if I'm working with filters on super massive images and multiple files. I'm honestly debating on upgrading this box to 32 or 64GB of RAM so I can increase the size of the ramdrive even further. It is not a hardware ramdrive though, it is a software driver loaded through device manager and you can set any amounf of the system ram as the ramdrive size, also can configure it to write the contents to a hard drive on reboot if desired, then reboot and viola Windows thinks it has a lot less ram and you now have a nice additional hard drive that simply spanks any hard drive or SSD in speed.
SO where did you get that Ramdisk software? I can't find it anywhere?
That sounds ideal actually. I don't think I need those hd's that you have and I am thinking that maybe the Q6600 might work out. I generally don't work on files larger than 1gig at all and don't open more than 2 or so at a time that big anyways.
I MIGHT start working on larger files soon though, getting possibly a new camera that does 37megapixel images, so yeah they will be large.
I am totally ok with having 16gigs or so of ram and using the ramdrive, but how can I set that up. Are you using a 64 bit OS?
Thanks
Ryan
Actually it the workstation in my sig and due to compatibility of other apps I need to run and the drivers for the printer (Flexi-Sign Pro and a 63 inch Mimaki) I'm forced to run 32 bit. The only good OS I could come up with that would truly allow the additional RAM, is current and updatable, and a 32 bit OS is Windows Server 2003 Enterprise. I simply disabled the majority of the server functionality, ran a few registry tweaks to enable themes, sound, etc so it pretty much looks and works just like XP Pro.
RamDisk software is by qSoft, it's actually developed by one guy but he has been at it for years now, updates it regularly and is very responsive to questions. He does have an eval version available to test it with and the price is VERY reasonable to buy it. I bought the full enterprise version and have both 32 and 64 bit versions so if I ever do upgrade to a true 64 bit OS I can still use it.
http://home.scarlet.be/~tsd59392/RAMDisk/ramdriv.htm#Overview
Good luck.
The problem with most desktop MOBO's is they only allow 8 gig of RAM. If you are thinking about a large RAM drive, you are going to have to move to a workstation or server based rig.
You are talking some serious cash then since most servers require more expensive memory.
Don
That is a good point..... the professional Dell workstation in my sige has 16 DIMM slots and supports up to 64GB or ram, but.... it will only run with FB-DIMMS which are generally well over double the cost of regular ram. I have well over 3 grand in this box and it would easily cost another 3 grand to pump it up to 64 gigs of ram.
wow
that is some serious amounts of RAM.
Question: Which setup would you use for OS drive for max speed? (assume SSD scratch disk)
150gb WD Raptor X 16mb cache vs. 3x RAID0 250gb 7200.10 250gb 16mb
*note: price AND reliability is NOT an issue*
The Raptor has a significantly faster seek time and prolly a better sequential read rate than a single 7200.10. Now 3 7200.10s in Raid 0 will not have any improvement in the seek time, but, their sequential read rate will be approximately 150 % faster.
If this is the case, then Raid 0 a half dozen (more like 9 actually) Mtron PRO SSD drives like these crazy nuts!
Raiding a couple of Raptor's is also an option.
Don
