Photogrammetry, 3d/2d workstation
Tashtego
Photo Editing, Photogrammetry, 3D Modeling/Rendering, web surfing, and movies
1300-1400 including tax/shipping
3) Where do you live?
New Jersey
4) What exact parts do you need for that budget? CPU, RAM, case, etc. "Everything" is not a valid answer. Please list out all the parts you'll need.
The whole thing: CPU, DVD burner, RAM, Mobo, video card, monitor, power supply, HD, case.
None
6) Will you be overclocking?
Maybe
23-25 inch 1920x1080
This month.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
Nothing specific
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? 32bit or 64bit?
Will be purchasing Win 7 Pro 64-bit
Hey guys, my friend is building a PC and he wanted to check to see how his build looks. He is not interested in gaming -- he is really using this as a home workstation. He considered a workstation video card (like a quadro) but is leaning towards a consumer gpu from nvidia (to make use of CUDA), and right now is just using the GTS 250 until something better comes along. Let me know what you guys think.
Build thus far:
LITE-ON 24X DVD
http://www.newegg.com/Product/Produ...Deals-_-na-_-na&AID=10521304&PID=3463938&SID=
ASUS VW246H Glossy Black 24" 2ms(GTG) HDMI Widescreen LCD Monitor
GIGABYTE GA-880GA-UD3H AM3 AMD 880G SATA 6Gb/s USB 3.0 HDMI ATX AMD Motherboard
ZOTAC ZT-20109-10P GeForce GTS 250 1GB 256-bit DDR3 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model F3-10666CL9D-8GBRL
AMD Phenom II X6 1090T Black Edition Thuban 3.2GHz Socket AM3 125W Six-Core Desktop Processor Model HDT90ZFBGRBOX
COOLER MASTER RC-692-KKN3 CM690 II Basic Black Steel ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119215
SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.425801
CORSAIR HX Series CMPSU-650HX 650W
With that budget I believe you could go with an i7 setup.
i7 930 + Gigabyte X58A-UD3R + G.Skill DDR3-1600 6GB
+ [insert gpu here] + the rest of the stuff you have. You should be able to fit that in the budget.
Should be roughly around $1300 and you will get better performance from the i7 than the X6
