Originally posted by Poiquiop
Don't worry, I'll disconnect it before I start anything. Never been zapped before though...
Originally posted by Vertigo Acid
umm, well I would unplug it first, because they can give you a nasty shock, especially if the phone rings while you're tinkering inside![]()
Originally posted by gies
If you get your power for the LED from the main phone line, remember that the power does jump quite a bit when it is ringing, i.e. You should filter out the jumps from your led with either a voltage regulator or a capacitor.
