phobia 400mm radiator enough
Discussion in 'Water Cooling' started by Jbort1984, Nov 26, 2012.
  1. Jbort1984
    Jbort1984 [H]ard|Gawd
    1,167
    May 28, 2009
    looking at water cooling my system when i finally get my new mobo wondering if http://www.frozencpu.com/products/1...erstone_Cooler_Master_Yate_Loon_Bitfenix.html Will be enough to cool a
    2600k@5ghz
    2x evga gtx 570 hd 1280mb editions
    I want to use http://www.xoxide.com/swiftech-maelstrom51-4-dualbayreservoir-w-dualmcp35xpumps.html or something like it
    My case is a second gen nzxt phantom and will be using the nzxt 200mm fans to push air through the radiator. Might be adding a 3rd gtx 570 down the road irf i can find a good deal on one.
  2. nightwalker
    nightwalker 2[H]4U
    2,555
    Feb 25, 2007
    You'd only need the version with 1 pump in that reservoir, not 2 of them for that loop. As far as the rad goes, i wouldn't feel comfortable using more than the 2 x 570's on it myself.
  3. JoeUser
    JoeUser 2[H]4U
    3,919
    Mar 30, 2010
    I'd say the radiator is WAY more than enough to keep the whole system cool...
    Just using basic math and experience a SINGLE 120mm radiator (in this case a all-in-one Kuhler 620) is enough to properly cool a 2500k...a Kuhler 620 also cools a GTX580.
    So if you have 2 video cards and 1 CPU 3x120 would efficiently cool the system FINE. I know the 620 cools my CPU to around 60-65C 100% load and when I had one on my GTX580 @ 975mhz it cooled it to around 60C.
    So considering the 2 x 200mm radiator is effectively 400mm and a 3 x 120mm radiator is 360mm I would venture to say that the radiator you have chosen is more than adequate and should perform admirably!
    I'm sure my thought process isn't spot on...but if a single/dual 120mm radiator is enough for a CPU and/or GPU...than yeah...thats plenty. Always get a second opinion though! :p
  4. Jbort1984
    1,167
    May 28, 2009
    Ok well i got 1 yes and 1 no on the rad so if i add a second single 120mm to the rear all should be cool
  5. Tsumi
    Tsumi [H]ardForum Junkie
    12,994
    Mar 18, 2010
    It should be fine, but a wrench in the radiator area equation is the fact that there are no fast spinning 200/180mm fans, and those fans generally have poor static pressure.
    It should be able to cool your system just fine, and if it can't, you can always add more radiators later.
  6. investinwaffles
    investinwaffles Limp Gawd
    495
    Apr 26, 2010
    It should be more than enough rad for the heat output, but like others have said there arent really any good fans.
    Running them push-pull would help with that though.
    Adding a 120mm rad with good fans would help out quite a bit, if you place the radiator in right spot in the loop (after CPU but before GPUs maybe).
  7. Jbort1984
    1,167
    May 28, 2009
    if i did the second 120mm rad in the back i was thinking of adding it inbetween the cpu and gpus to make my loop go
    Res/pump
    400mm rad to cpu
    120mm rad to gpus
    back to res.
    or is there a better way to do it.
  8. Tsumi
    12,994
    Mar 18, 2010
    Loop order doesn't matter if flow rates are high enough. Just route the tubing as cleanly and as organized as you can.
  9. Jbort1984
    1,167
    May 28, 2009
    tha why i went with that loop order just seemed to me it would flow easier and i would be able to keep the internals of my case looking good
