Philips snu5600, won't install.
ebilcake
Trying to get this thing to work for a m8 but the driver will just not install for the usb wifi adaptor, the installation does nothing and it won't install manually either.
Anyone have any experience with the snb5600? hes using windows xp.
So I Googled snb5600, and it comes up as a router. Are you having problems with the WiFi router or the USB WiFi Adapter? If the adapter, which model is it?
Yes, it's the snb5600 router, it comes with a snu5600 usb wifi dongle thing and it's that we are having trouble with, I basially get as far is it asking to insert the snu5600 but after inserting it nothng happens, no drivers install, I located the drivers on the cd and tried to install manually but thats not working either.
The usb connections are all working properly.
