Just reading through the specification and Iam convinced its using the new 23" AS-IPS panel since the spec closely matches the NEC 20WMGX2, the only thing that bothers me is the DVM mode on the NEC which achieves 1600:1 contrast ratio from the normal 800:1(which the philips doesnt have). The NEC resolution is going to be problem so thats out, the only solution is a 23"/24" AS-IPS based panel.
