There is someone on XS running the same setup,might want to take a gander there.
First off your CPU mulitplier is set at 5.5X, stock is 11x for the 9500. Your FSB is set to 200 so you are really only running the chip at half speed. Also your HT multiplier is at 1x, while the stock value is 9x.
One person reported that they fixed a similar problem by going into the BIOS and setting "Cool & Quiet" to "Auto" instead of "Off".
