Phenom Overclocking Help?
Thawaxshop
Bad Trader
Well its been a LONG time since i messed with AMD and i have some stuff i bought to just try, First off heres what i have.....
Phenom 9500
Gigabyte MA790X-DS4
Crucial DDRII-1066
HD3850
Zalman 8700
Now i cant get this thing to budge? What am i missing? Easytune freezes the comp, overdrive doesnt have the options and anything i move in the bios hangs....
Lots of good advice below-
http://www.xtremesystems.org/forums/showthread.php?t=167447
The general AMD forum is good there too-
http://www.xtremesystems.org/forums/forumdisplay.php?f=58
Make sure you select "advanced" in AoD. It defaults to basic-
http://img86.imageshack.us/img86/7061/aodxf8.jpg
In an ideal situation you will be able to locate a BIOS for your motherboard that allows the manipulation of AM2+ P-States. (If it doesn't already) That will allow you to keep you motherboard northbridge speed @ or below 2k. KTE talks about it in the linked thread. X-bit talks about it here too-
http://www.xbitlabs.com/articles/cpu/display/amd-phenom9600-be_8.html
