Phenom II X8
Curious - what's the power draw of those CPU's with only 8 threads pulling that weight?
hmmm... i'd have to run all 48 cores at 2.1 Ghz to establish a baseline... then run 8 cores at 3.3 Ghz to see what the difference would be. i'll try that tonight.
btw, 3.3 Ghz... is achieved at 1.225 volts... anyone know what the stock voltage for the Phenom X6-1100T was at 3.3 Ghz?
The stock BIOS voltage when you set it to Manual was 1.375V. That was way too high. You could undervolt them to 1.30-325 easily and run them to 3.4 GHz. You could probably go lower but I always left it at 1.325 as that gave me really good temps even on the stock cooler.
Do you know what the voltage levels were for the cores that were boosted under turbocore?
