My main question is, how much do these chips overclock?
I got the system about a week ago, and today I started messing around with the clocks. Since it's a BE all I've been changing are the CPU multi, CPU vcore and the HT voltages.
The CPU is stock 3.0 (15x), 1.35v
I immediately put it up to 3.4 (17x), and noticed it wasn't stable. OK, I bumped up the vcore. At 1.375v I was able to boot into Windows 7, but it still wasn't stable. Again to ~1.386v. Now it's stable, 10 minutes under AMD OverDrive (that's just my baseline since I'm still in the process). Now, I rebooted and tried to go a bit higher. 3.6 (18x). Booted, but BSOD right when logging in. OK, bump up to 1.4v, same thing. So I went back down to 3.4, and the originally stable 1.386, but it wasn't stable, everything was crashing and the stress test failed. I'm now at 3.4, 1.4v running the test fine, but I'm wondering: is this a good overclock? High/low? Last thing I really tried OCing was an Opteron 165, so I'm not that sure how the Phenom IIs work or what to expect. Temps are a bit high from what I've heard (I hit 52 at 100% load), but I really want to get it above 3.5.
Thanks guys.
Thanks guys.
