I just upgraded my old Athlon 64 3500 to a Phenom II X4 920. I got a great deal on the chip and I had heard really good things, especially about how cool it ran even with the stock cooling. My results were far from cool. The stock HSF had my non-overclocked chip hitting 45C at idle and approaching 60C after only a couple minutes of prime. After receiving multiple errors in prime I sent my stuff back to newegg for a replacement.
Are these temperatures normal for a Phenom II? I reseated the HSF and reapplied arctic 5 three times without any significant change.
I decided on my replacement P2 I am going to go with aftermarket cooling regardless. My problem is that all the normally recommended options like the xigmatek, etc, are all oriented with the fan blowing hot air off my 8800GT directly into my PSU. The orientation for intel is always ported out the exhaust fan on the case, however.
Are there any good cooling options for AMD that are oriented correctly? Does it actually matter? All the benchmark reviews show the xigmatek performing great, but the benchmarks always negate the real world application. They either watercool the video card or run synthetic tests it seems.
Thanks
Thanks
