Phenom II 710 Voltage Question,
donnydorko
I keep getting conflicting reports of what the maximum safe voltage is for the Phenom II 710 processor.
I currently have it at 1.41 clocked at 3.3 ghz with the 4 core unclocked.
I want to push it more but believe i will have to up the voltage sum to achieve this.
Alot of people say you can hit 1.5 with no problems voltage wise as long as you have good cooling but on the amd site it says 1.3 - 1.425 as the voltage.
On the phenom II quad cores it has a range up to 1.5
I have an artic freezer pro 64 as my cooler with idle temps at 41 c, and prime stress testing hitting 52 c.
Thanks
I consider 1.5 safe top, 1.55 outside. Of course depends on cooling & temps.
If you are keeping under 60c load you should be good.
