Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I just installed a 1035T and overclocked it to 3.0Ghz. It seems to be running fine, but I can't find the temp on the bios, cpu-z, or everest. Anyone know about how fast I can push this chip with a air-cooled but aftermarket HSF?
use coretemp. with the right board you should be able to do 4Ghz no problem with that thing. it will just take a lot of finesse work with the other NB/ram/HT multipliers.
yeah they are all based off the same 1090T chip, most of the 1035T's now are actually perfectly working 1090T's just declocked to meet OEM demand pretty much.
