Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I have a question with regard to phasechange cooling: just how difficult is it to install a phasechange cooling system if you have never done it before?
I had to dremel too. I got the prometia phase changer and a lian li case, to get the hose to the cpu i needed a hole in the case. No biggie, I did mine indoors though, weather doesnt stop me.
