phase changin, noob needs help?
Teknokid
i just found this technology on the internet, and i want to learn more.
i have a few questions though.
Im looking at the vapochill light speed.
1) how long does this sort of kit last?
2) can you kill them with too much heat? (how far could a q6600 go)?
3) is it worth it? would a good water cooling set-up be better?
cheers
a un-modded LS on a high OC'ed quad is no good. You would be better off with high end water IMO.
My friends vapochill died after 1.5 years so he gave it me.
I found the controller board for the compressor had gone.
The repair was £120 if I fit a new controller to the compressor myself but I decided to not bother in case there were more faults that caused it to die.
Its gotta be fun to try one out but my PC is on 24/7 so it wouldnt be suitable for me.
